Beta 2: Mount Peril - Printable Version +- Midnight Mansion Forums (https://actionsoft.com/forum) +-- Forum: 120 (https://actionsoft.com/forum/forumdisplay.php?fid=10) +--- Forum: 999 (https://actionsoft.com/forum/forumdisplay.php?fid=55) +--- Thread: Beta 2: Mount Peril (/showthread.php?tid=1326) |
Re: Beta 2: Mount Peril - hawaii - 04-18-2010 15897 - Normal I think that there should be a lever at the top left ledge. If Jack should fall in the below room, he reappears on the up ladder to this room. Rather than make him go back & do everything all over again, there should be a lever in this room to change the yellow block wall. Re: Beta 2: Mount Peril - hawaii - 04-18-2010 15497 - Normal 1) If Jack falls off the moving yellow platform trying to p/u all the coins, the yellow platform does NOT return after Jack comes back to life to allow Jack to finish picking up the coins. 2) After Jack takes a ride on the Bat Brick, to the NEXT ROOM, if he dies killing spider, he doe NOT reappear in room 15499, instead, he reappears in the 1st room 15497. Re: Beta 2: Mount Peril - Semi-Native - 04-18-2010 NORMAL 16900 Jack can get the key just by jumping while riding the platform. Doesn't have to pull the lever. 15704 One of the ghosts doesn't appear, so the bridge can't be triggered. It's the 3rd ghost down in the group of 4 on the right. (In the editor, I changed that ghost's horizontal distance to 300, and now it works.) Re: Beta 2: Mount Peril - hawaii - 04-18-2010 15497 - Normal When Jack finally p/u the green key in room 15497 & falls off yellow moving platform, he reappears in room 15698 instead of room 15497. This room is not the same as below posted pic, as the invisible brick pattern is changed now, allowing to p/u the green key. 15899 - Normal If Jack goes exploring, and swings down onto the vine, he can't get back up to the ledge unless he dies. 16300 - Normal Am I missing something? How does Jack get to the Bat Brick in the room to the LEFT of this one? There is no room number on the MLB. 16501 -Normal The cave ceilings above the vines DO NOT allow Jack to smoothly jump to the RIGHT from the top left ledge, without getting killed by the lady bug or falling to his death. The jagged edges are in the way. Try it in the tester room & see what I mean. This room is way to busy with creatures to jump RIGHT properly. 16700 - Normal Jack dies trying to p/u MAP from the right side ladder, if he did not p/u the map from the left side 1st. NOT GOOD. Re: Beta 2: Mount Peril - hawaii - 04-18-2010 16500 - Normal HELP PLS. for the life of me, I can't figure out how to lower the grey panel to p/u the yellow key 17300 - Normal FYI: There is a real sneaky secret to the right of the top right ladder. Do not climb the ladder, just jump to the right of it to check it out. Re: Beta 2: Mount Peril - hawaii - 04-18-2010 023C3B322C550 wrote: ... hmm? What would a new player be doing on normal mode? They should do easy first, and in easy I'm going to make it so if you've played it before, on normal you'll know what to do with no problem, as long as your MM skills have increased. Beg to differ. I was a brand new player & still checked out the Hard & Normal games 1st. Curiosity is just human nature. Also, even if a player starts out in Easy mode, by the time they return to the harder versions, they won't remember the game play. Re: Beta 2: Mount Peril - Semi-Native - 04-18-2010 636A7C6A62620B0 wrote: 16500 - Normal I don't know if this is what the designer intended, but you can jump on top the gray door as the yellow platform is going up, go get the yellow key and then the lever opens the door for you. Re: Beta 2: Mount Peril - hawaii - 04-18-2010 65535B5F1B7857425F4053360 wrote: [quote author=636A7C6A62620B0 link=1271354044/14#14 date=1271618612]16500 - Normal I don't know if this is what the designer intended, but you can jump on top the gray door as the yellow platform is going up, go get the yellow key and then the lever opens the door for you. Then this is a definite problem & should be fixed. But, if you look at the MLB, there is a moving brick in there??? Thank you for your prompt reply. Edit: I am jumping & jumping as per your instructions & can't get past that darn flaw.....!!! Oh, I now did once & Jack plummeted to his death! This is a definite flaw in the game. Re: Beta 2: Mount Peril - hawaii - 04-18-2010 15704 -Normal Hmmmm, the BB sign says to find all 5 ghosts before you get to this room. So Jack killed many ghosts, but in this room 15704, music & stars come on, so Jack hunts and hunts for a ghost. It does NOT MAKE SENSE to have Jack climb down the ladder & JUMP TO HIS DEATH (to the right) to make the ghost appear, just to make the skulls appear below. 15301 - Normal BTW: DUE TO THE JACK STUCK that Semi-Native posted on previous page, room 15301, Beta Testing of the upper part can't be done until an update link is sent. 15502 - Normal The Blue Bat Brick disappears if Jack goes down the vine & back up again. It should stay there and allow him a short cut back to the spot he started from and NOT make him take the long way around again. my opinion only. 15708 - Normal Jack always reappears to the left of closed grey panel if he dies. It does reset itself if he leaves the room. Re: Beta 2: Mount Peril - hawaii - 04-18-2010 15701 - Normal I think there is a yellow platform with a lever missing in the spot that Jack is standing in? Maybe that would help in the J.S. room? |
