Beta 3: Mt. Peril - Printable Version +- Midnight Mansion Forums (https://actionsoft.com/forum) +-- Forum: 120 (https://actionsoft.com/forum/forumdisplay.php?fid=10) +--- Forum: 999 (https://actionsoft.com/forum/forumdisplay.php?fid=55) +--- Thread: Beta 3: Mt. Peril (/showthread.php?tid=1343) |
Re: Beta 3: Mt. Peril - sherryl199 - 06-03-2010 Rooms 14902, 15697 & 14702 - Wonderful mansion - can't wait for the Hard version?! I also had the green key situation in 14902 and two anomalies that I haven't been able to reproduce. Once, in room 15697, when Jack jumped from the bat platform to the yellow up elevatorplatform - after hitting the gold bricks - he just continued up into oblivion. The second, in 14702, the blue haired bat boy, disappeared and would not reappear either by Jack leaving the room or suspending and restarting the game. I'm in the process of sifting through lots of movies to see what might have happened in the latter 2 instances. There are a lot of keys in this mansion, but I felt the maps made it easy to navigate between areas. The challenge of getting all the keys made the mansion very interesting. Re: Beta 3: Mt. Peril - rose - 06-11-2010 I have finished Mount Peril 3 times now and still can't find all secrets. Best result 77%, 14 secrets. Found two rooms I missed when I looked in the MLB. I apologize if some parts already are mentioned. Here are some thoughts. Some parts are more for the hard version. for example hidden save point room/s. Who will think of going from 15696 to the left. It does look like a solid wall. 15707, Who thinks of going down from 15707 to the dark rooms? Some indication would be nice and proper. There are some more like that in that section! 14702 if going back up with the blue mobile brick it stops just under the green floor. Why not let it stop at the starting position? In room 17096 is it possible to get the shield without dying or has one to die? It doesn't make sense when there isn't any gain from it. 15102 there is a coin beside the ladder which Jack can't get! I think Missy has reported this. 16102 no indication that one can jump to the room on the left. Re: Beta 3: Mt. Peril - Wingy - 06-11-2010 6E736F791C0 wrote: I'll remove the fringe. 6E736F791C0 wrote: The indicator you're looking for is the red candle -- if you read the sign in the room above this one, the 'ghosts' will tell you this. 6E736F791C0 wrote: Sounds like a plan. 6E736F791C0 wrote: The room number you gave doesn't seem to work, can you double check your room number, please? 6E736F791C0 wrote: Yep, this will be fixed for beat 4. 6E736F791C0 wrote: Sure there is, you can see the secret on the other side. Thus players will know the way to get to it would be a false wall on the other side. Thanks for your comments Rose!
Re: Beta 3: Mt. Peril - rose - 06-11-2010 Read it but I haven't seen any red candles anywhere.6E736F791C0 wrote: 6E736F791C0 wrote: Deleted image as it was the wrong mansion! No, not from room 16102. I wish there was something, small change in colour or texture.6E736F791C0 wrote: Re: Beta 3: Mt. Peril - divadnala - 06-11-2010 Rose - the room 17096 in your picture is in Magma Peak. There is no room 17096 in Mount Peril. Re: Beta 3: Mt. Peril - Wingy - 06-11-2010 I believe the room you posted is a room from Magma Peak, not Mt. Peril. I'm still not sure about your other problem, in terms of jumping between rooms -- Im not sure. Re: Beta 3: Mt. Peril - rose - 06-12-2010 Oh, I will look into that. Deleted image above as it was from MAgma Peak and not Mount Peril. And I have seen the red candle now!!! I must be blind as a bat! |
