Beta 2: Mount Peril - Printable Version
+--- Thread: Beta 2: Mount Peril (/showthread.php?tid=1326)
Pages: 1 2 3 4 5 6
Re: Beta 2: Mount Peril - hawaii - 04-19-2010
15103 - Normal
Both rooms are in the MAP PIC below
Jack can't get out of this area, with the 2 spiders, if the grey panel on LEFT, was not opened before he entered the area.
15302 - Normal
Also, Jack can't pick up the red key if he is on the green key LEFT side.
In MLB Jack appears on the RIGHT, & the invisible brick appears, but NOT if he is on the LEFT side.
Also, the ladder above the red key, between the 2 upper leavers.....Can't be accessed with Blue Bat Brick from above room 14902, because the red floor panel keeps closing when Jack leaves the  room, after the Goblin opens it.
14902 - Normal
Jack Stuck - The grey panel doors don't stay open when Jack came back from the left after opening them from the right.
The Goblin has to open the red floor panel, but they don't stay open when Jack re-enters the room. ????
Actually, all the red floor panels keep closing when Jack leaves the room, preventing the blue bat brick from going down to get the red key
Re: Beta 2: Mount Peril - Wingy - 04-19-2010
696076606868010 wrote: 15103 - Normal
15302 - Normal
15103 - How did Jack get past the grey door without opening it?
15302 - The only way to get the red key is via the blue bat platform from above.
There is a reason the blue bat platform is so slow. Remember, Blue Goblins are your friend.
474E584E46462F0 wrote: 14902 - Normal
1: This isn't a Jack stuck.
2: Like I said before, there is a reason why the blue bat platform in the room abouve is so slow.
On a side note, I've carefully tested these sections to the best of my knowledge, so don't assume the section isn't possible to beat, because it is. Wink
2: There is a reason why the blue bat platform in the room abouve is so slow.
You got to be kidding me???? Maddening, just maddening!
I have opened the 1st red floor panel with the Goblin, but the ones below are also closed. Are you telling me that Jack has to run and pull leavers all the way down?
2E2731272F2F460 wrote: [quote author=033D3A332D540 link=1271354044/32#32 date=1271646226]
Well, what els are you meant to do during a boring, slow elevator ride? Big Grin
Then there should be a save right before going down the Bat Mobile!  lolololol  I don't even remember which levers open those darn red doors.
Quote Anthony:  15103 - How did Jack get past the grey door without opening it?
Answer: Scroll down to pic of area Map....see the very top level (with the 4 green columns).  Well, Jack jumped onto the skulls on the very right side and got down there that way.
Ah, I see. I'll put a wall on the top level so players can't jump down like that; from the top to the middle.
Anthony, this is too weird.... I did use the Goblin to open the red floor panel while going down the Bat Mobile, but the other red panels were the ones that were closed......hmmm maybe, I'm overtired and forgot to open them just before I posted. Maybe you should delete all these posts so as not to clutter.
16505 - Normal
Jack can't go back up to search for keys!  There was no BB warning him of the colours he must have before going down, as it is a one way ticket.  Some players (including me) like to be able to go back.
Okay, FINALLY FINISHED NORMAL.....BUT NOW, I AM NOT NORMAL!  ;D   Tongue :-X
One blue key left over????  Talk about a creative guessing game mansion.
Re: Beta 2: Mount Peril - Semi-Native - 04-19-2010
15102 Normal
Jack opened the red trap doors already, and now there's no room on the top ledge to open the green door. I suggest moving the green door a little to the right, to give him a spot to stand. You can't put anything in the space for him to jump on, because then it will block the platform from above when it's coming down.
15701 Normal
It seems that the right blue door must be opened first. I took the left door first, and then didn't have a purple key in 14903 (so I cheated and gave Jack one). Without it, I couldn't have gone any further. And I ended the game with an extra purple key, so that makes sense.
