Cannot access saved versions of custom mansion - Printable Version +- Midnight Mansion Forums (https://actionsoft.com/forum) +-- Forum: Midnight Mansion 1: HD version (Mac and Windows) (https://actionsoft.com/forum/forumdisplay.php?fid=8) +--- Forum: General issues and game bugs (https://actionsoft.com/forum/forumdisplay.php?fid=43) +--- Thread: Cannot access saved versions of custom mansion (/showthread.php?tid=1876) Pages:
1
Cannot access saved versions of custom mansion - Matari - 09-04-2011 Hi - I am playing my game (Questing for the Rainbow Key) but when I want to access a save, I get the attached screen. Am I doing something wrong? Re: Cannot access saved versions of custom mansion - brell - 09-04-2011 Hmm... it looks like a bug in one of the beta versions. Let's see what Vern says. Re: Cannot access saved versions of custom mansion - Matari - 09-04-2011 Thanks Brell. Re: Cannot access saved versions of custom mansion - RobSeegel - 09-05-2011 78544154475C350 wrote: Hi - I am playing my game (Questing for the Rainbow Key) but when I want to access a save, I get the attached screen. Am I doing something wrong? Did you put your game into the directory that the game creates? Or did you open your game from another location on your computer? Re: Cannot access saved versions of custom mansion - Matari - 09-05-2011 Hi Rob - I put the game in the directory the game created when I pressed on 'open mansion'. Re: Cannot access saved versions of custom mansion - RobSeegel - 09-05-2011 18342134273C550 wrote: Hi Rob - I put the game in the directory the game created when I pressed on 'open mansion'.Matari, Here's a In your Custom Mansion folder, open your mansion zip file. Now when you press open mansion, select the expanded directory that contains the contents of your zip file. Play that and save it, abort the game and restore - it should work. I just created a simple mansion to test it. I'm sure that Vern intends to be able to save/restore from a zip file as well. I forwarded the information to him so that knows about the inconsistent behavior. Re: Cannot access saved versions of custom mansion - Matari - 09-05-2011 Hi Rob - Yes this worked, thank you. Re: Cannot access saved versions of custom mansion - rose - 09-05-2011 This is what I did Re: Cannot access saved versions of custom mansion - RobSeegel - 09-05-2011 627F6375100 wrote: This is what I did The problem with that Rose is that any player who gets the game from the Apple AppStore is not going to see the same structure as what you've laid out, though it is close. Under Applications, they will see (among many other apps): Applications + -- Midnight Mansion HD - Episode 1 + -- Midnight Mansion HD Custom Mansions The Custom Mansions directory will be created the first time someone goes to open a custom mansion. The Game Data is now bundled under the app. Are you saying that you moved things around to keep the game components together? Re: Cannot access saved versions of custom mansion - VernJensen - 09-05-2011 I will look into fixing this. |
