Threads: 248
0
Greetings again,
My latest on MMandM is that I am now in room #16335 -
Jack apparently has to get up the rope on the left side of the room, but he keeps slipping about 3/4 of the way up.
My guess is that some sort of pyrotechnical jump is required.
Tell me how.... please? :
Thanks much!
DLC
Threads: 1,481
0
No need for the rope
Threads: 340
0
Wow, dlcatftwin, you sure have a way of finding stucks in MMaM! I only played 100 rooms or so and gave up! It just went on, and on, and on, and on, and on, and on, and on, and on, and on, and on, and on, and on, and on, and on, and on, and on, and did I metion it went on?  :
Now I better get my time together and play it...
Threads: 248
0
And on and on and on...
Plus... I know I have missed a couple or three junctions in the process that I can't go back on, so, I guess I gotta do it again (ahhhhhh!).
There was one maze (the one with all the eletrical zappers) that i just gave up on
(I *hate* zappers! >  )
But thank you for the hint, Brell - I gotta go try it!
Best regards,
DLC
Threads: 869
0
I hate zappers, too! >
I think you can actually go back anywhere in the mansion until the very end, but sometimes it is easier just to start over from a save point.
Carry on!
Threads: 1,481
0
Yes, that is right. Until very near the end.
Threads: 2,609
Hello dicatftwin !
Thx for trying to find your way through MMaM. I see that you are already in the very hard area now. Congratulations. But of course the problems are more complicated in this toughest part of the mansion. Brell was right about the rope, btw.
Threads: 248
0
Hi Freddy,
Thakns for the post.
I have negotiated some trickier rooms since my last post - Brell's hint was right on and i found the hidden ladder - clever!
I was able to play one pass through what was labeled as Magic Maze then I started going back (up), played through a room called Sea Mines and in the layers below discovered a secret i missed (yum!  ) which led me to my current location - I doubled back and am in room 15940, but I can't hurdle the middle obstacle - is this accurate? Also, I wanted to get beyond the magic maze area and get to what I know is a big area beyond (it contains that there ultimate maze) - but i couldn't find the door! A clue. por favor?
Thanks for a great puzzle!
-DLC
Threads: 2,609
It must be asked once! Are you a twin? And maybe Spanish?
To answer YOUR questions.
1° In room 15940 there is indeed a hurdle that prevents Sir Jack from going back from right to left. (Since House of Coin Jack is now a Sir!)
2° Go back to the room where you saw Magic Maze and have a closer look. You may also restart MMaM at the save point over there.
Keep in mind that the Ultimate Maze is ... ultimate. As a puzzle, it is the toughest problem of Midnight Mazes and Monsters.
Threads: 248
0
Hello Freddie,
Thanks for the response. I did figure out how to double back and thank you for the clarification (yes I went back (to the right) and up and over and down, as designed!
I will give Magic maze a closer look; any particular room I should be perusing?
To answer your questions: no to both  though my sis had twins, so there's some in the family.
Thanks again,
DLC
P.S. I am now in the room with the impossible conveyer belt #2 - argh! it is hard!
